1959 super seahorse 35 impeller
Globejs86
Well I managed to get the LU off. Not excited to try and get it back together.
The impeller seems to be I'm pretty good shape. Not cracks or brittleness, a couple creases on fins but nothing deep or about to break off.
Is the impeller supposed to be pretty tight in there? It seems pretty tough to spin the driveshaft once it's on.
Before I took it off I could hear squeaking when I rotated the flywheel. Sound normal?
I also tried to start it but the starter couldn't handle it with the plugs in the holes, did fine without them plugged in. It rotated pretty slow maybe 2 rotations a second. I think it's somewhat gunked up up in the cylinders. Not sure what to do about that. I started to take the cover off the cylinders but I encountered a couple bolts that I rounded out so I'm kind of screwed for removing and gunk manually.
I heard putting oil in there through the plug holes and rotating the flywheel can help. It's so tight I can't pull start it so I need to do something. Compression was at 80 and 90. Is it use able?
F_R
Honorary Supreme Mariner
Yeah, it is supposed to be quite tight in there and yes it might squeak if dry. Were those compression readings with the electric starter or recoil starter? If the recoil, did you disable the compression relief valves?
jimmbo
Replace the impeller. It has cracks on the backside by two of the tips. The blades also look like they have run backwards or the impeller had been flipped over before.
Soapy water or a silicone grease will make the impeller installation go much easier
oldboat1
You might be making some hasty assumptions that can be costly (or time consuming). Chances are, slow cranking is not because cylinders are "gunked up." When you get the cylinder cover off, however, resurface the mating edge before reinstalling to correct warpage (will need a new gasket).
Don't test any further without getting the water pump in shape, as you appear to be doing. Test only with the lower unit in water. (You will hear an feel resistance from a dry impeller when turning the shaft by hand, or immersed in a tub for that matter.)
It sounds as if you were assuming earlier that your new battery was DOA(?) Wiring issues are far more likely. Need to take sandpaper to every connection, and check every wire.
Globejs86
I thought the battery died because I got the starter to work when I first hooked up the battery. Then 2 days later it wouldn't start. When I put the battery on the charger it said it was charging and I left for work and 8 hours later it said it was charged. I don't know if it took 2 minutes or 8 hours. When I tried again though it still didn't work. I got my compression reading with the starter by bypassing the new starter solenoid I just put in. Only the compression tester was plugged in so the other cylinder was open.
The engine is too difficult to turn over with the cord with both plugs in. It's and uneven resistance. It comes and goes when rotating the flywheel.
I'm not sure if I'll be able to open up the front. I rounded two bolts and I can't get to them with anything but a socket which just spins.
I tried to remove the smaller panels held on with flathead screws, but those too were siezed. I've tried a hammer,heat,pb blaster, vice grips and haven't had luck yet. Guess I'll need to keep trying.
What should I do next? I really wanted to see if it would run before buying an impeller. It's not in such bad shape it won't work to test the motor. I'm willing to add a new one later after seeing get if it will run. set the points already and cleaned the carb.
Not that you haven't already figured it out, but I've never owned and outboard or worked on motors norepinephrine than basic car maintenence so bear with me in this learning experience. I truly appreciate the help. It's all pretty cool stuff to learn. Maybe it'll pay off in the end with this motor working. I'm prepared for it not to though.
The 2 grommets in the pump do not look very good in the picture.
jimmbo
"I thought the battery died because I got the starter to work when I first hooked up the battery. Then 2 days later it wouldn't start. When I put the battery on the charger it said it was charging and I left for work and 8 hours later it said it was charged. I don't know if it took 2 minutes or 8 hours. When I tried again though it still didn't work. I got my compression reading with the starter by bypassing the new starter solenoid I just put in. Only the compression tester was plugged in so the other cylinder was open."
Are the cables, connectors all corrosion free and tight? Have you had the battery checked for capacity?
"The engine is too difficult to turn over with the cord with both plugs in. It's and uneven resistance. It comes and goes when rotating the flywheel."
What you were feeling is most likely, the compression stroke
"I'm not sure if I'll be able to open up the front. I rounded two bolts and I can't get to them with anything but a socket which just spins.
I tried to remove the smaller panels held on with flathead screws, but those too were siezed. I've tried a hammer,heat,pb blaster, vice grips and haven't had luck yet. Guess I'll need to keep trying."
Open the front?
"What should I do next? I really wanted to see if it would run before buying an impeller. It's not in such bad shape it won't work to test the motor. I'm willing to add a new one later after seeing get if it will run. set the points already and cleaned the carb."
Well that means two disassemble/reassemble operations. What condition were the coils in?
"Not that you haven't already figured it out, but I've never owned and outboard or worked on motors norepinephrine than basic car maintenence so bear with me in this learning experience. I truly appreciate the help. It's all pretty cool stuff to learn. Maybe it'll pay off in the end with this motor working. I'm prepared for it not to though"
Well consider it a learning experience
