Revelation
Thread starter- Joined
- May 8, 2009
- 23
I was given a 16ft jon boat with a 1959 Johnson QD-20 Seahorse 10. It had been sitting for over 5 years with gas in it. I cleaned out the carb, ended up rebuilding the carb with new synthetic float, it still wouldn't run. I replaced plugs, and I took the view port off the points and reset them to the .020" that is marked on the head. (Everything inside view port looked shiny and new with no corrosion.) I managed to get it started with a little starting fluid and lots of pulling. Ran well for 5 minutes at idle after I set the slow idle adjust on carb to where it is running smooth, but when I tried to adjust the fast idle on carb, I could not get it running smooth. At full throttle, it doesn't appear to have much more power than at slow idle (in or out of gear). I have not tried a compression test, yet. My next attempt at getting it running is going to be using SeaFoam to clean out the engine.
I had written this project off, until I was bored this past weekend. Since, I got it running, although roughly, my motivation is revived. Any help would be great!
