1959 Lark 35hp Carb Fuel Delivery Issue...I Think
cnnrklly
Hello, First time posting on iboats.
I have a 1959 Lonestar Flamingo w/ 35 hp lark evinrude to match. Boat had been running fine on the lake all last year. Ran the boat 2 times this season without an issue. 3rd time out this year the motor stalled out while cruising. No luck cranking it back up. Fuel started coming out the carb when cranking. I disconnect the fuel line to crank out the cylinders (thinking the engine was flooded) With the fuel line disconnected it cranked right back up. I reconnected the fuel line and off I went....back to the boat ramp anyway. So I figured it was hot out and my carb needed adjusting and that was it....wrong.
Now everytime I crank the engine it will sputter then start pissing fuel out the back side of the carb. So I figured my float is bad. Took off carb put on new float. Started right up in the driveway. Took to the lake, started up, died. Started pissing fuel out back of carb.
Checked spark, spark is fine.
Disconnected fuel line and cranked for a while. It fired up, reconnected line, it died.
I have attached a picture of where the fuel is coming out of. It seems as though it is pumping way to much fuel in the cylinder and flooding the engine. When fuel line is disconnected and the fuel in the line and engine starts to dissipate then the engine fires right up....Thus, HELP
