1959 Johnson Super Seahorse 35 No Forward Gear! Please Help
aschaaf
I just recently bought a 59 johnson super seahorse 35 as my very first outboard motor. The guy I bought it from started it up to show me it worked and it ran beautifully.
Today I took it out on the water for the first time. Started right up, idled great, reversed out of dock area great, but when i try to put it in forward it just stays in neutral. There is no "clunk" to indicate it shifting, like it does when i put it in reverse. it just acts like it is in neutral and doesn't engage the propellor. A couple times it very very slightly pulled forward a tiny bit when it was put in forward but that was it and it only did it a couple times out of my many attempts.
I know it is not the linkage because I took the linkage off and manually pulled the lever into the forward gear and it still didn't work. I have never worked on an outboard motor before but I have worked on plenty of car motors before so I am willing to give it a shot. I just don't know where to start.
And ideas what could be wrong with it? Where do I buy parts for such an old motor? If I do give up and take it into a shop how much would this type of repair cost me? Am I better off just buying a new motor? Any help is much appreciated! Thanks in advance
F_R
Honorary Supreme Mariner
There is a plate on the side of the midsection, held on by two screws. Remove that plate and you will find another one behind it. Remove that one too, and you will find the shift rod connecter inside. Now see if the connector and upper&lower rods are moving when you operate the shifter lever. Difficulty and cost depend on what came loose.
Parts are available from Evinrude dealers and some on-line dealers as well as BRP, current maker of Evinrudes. The great majority of shops won't touch motors that old. You just started on your new hobby -- fixing old outboards. Be careful, it's addicting.
aschaaf
Thanks a lot! I will check that out after work today and see what I find.
Chinewalker
It is also possible the shift handle has come loose up top. I believe the outer handle is bolted through the belly pan into a piece that has oblonged holes to allow adjustment. If it is loose, or has been tightened such that the handle is too far aft, then you may not get forward engagement.
aschaaf
Thank you I will check that out as well. Hopefully I can locate the source of the problem. All suggestions are much appreciated!
iggyw1
Ensign
I had the same problem with an old Evinrude that I had. It was definitely the shift rod not being placed into the upper & lower rod connector properly. The connector is inside the side plates that F_R mentioned above. First off, when you go inside the side plates, ( two of them, one outside the motor housing, one inside) be very careful that you do not drop the screw that is holding the shift rod connector onto the shift rod. If you do, you will need to removed a lot of things to get that screw out! After I did that, the second time I did it, I tucked a rag inside the area below the connector so IF I dropped the screw again, it would not go far. I did not drop it again!! Long nosed pliers work to get the screw out once its all the way loose. ALSO, disconnect the shifter cable from motor.
Second, DO NOT remove the upper screw on that connector. ( you may have to later if the upper screw is not properly placed into the upper rod indent). Leave that one tight onto the upper rod. Remove the lower one only when the shifter is in the neutral position. After removing the lower connector screw, put your shift lever (manually on the side of the motor) towards the forward position NOT ALL THE WAY. Just a little bit. This will raise your connector which is still attached to the upper rod, and the lower rod would then be a bit lower inside the connector so when your are finished, the rod will go deeper into the gear box for you. You can check your results when you get the bottom screw back into place and tight, you should be able to turn the prop in both directions in neutral, only one way in forward and the other way in reverse. You can do this testing by working the shifter by hand while spinning the prop by hand too. Make adjustments as needed by removing that bottom screw and moving the bottom shift rod up or down into the connector as needed. Both rods have an indent in them so the screws will go thru the connector into the indents on the rods. Should look in a repair manual or at least a parts diagram on line to get a picture of the entire set up so you understand what I am meaning by all of this.
The situation probably happened because the previous owner replaced the water impeller and did not insert the shift rod into the connector like it was when he started the water impeller replacement.
aschaaf
So dispite my best effort the little washer that was on the screw fell when I was removing the bolt. So what now must I Remove to retrieve it?
I think you are right on on the problem though. I person I bought it from said it had a new impeller
F_R
Don't worry about the dropped star lockwasher, it won't hurt anything in there. Just put a new one on the screw and call it good.
aschaaf
Thank you everyone for all the help I think I have the problem all figured out! This forum and its memebers are the best.
aschaaf
So I got a new shift rod connector, the old had stripped threads. I also got new bolts for it because the old ones were very worn. My problem now is no matter how many times I adjust it, I either have only forward or only reverse. Even with the slightest adjustment. Is there anything else that could be worn causing the shift rod to move slightly and not lock into gear? Or do I need to keep messing with the adjustment of the connector?
aschaaf
I can get it where it locks in gear both forward and reverse while turning the prop by hand, but as soon as I put it in a barrel of water and test it it slips out of one of the gears.
When you replaced the connecter did you line up the notch in the shift rods with the hole before putting the bolt in ?
aschaaf
Yes I did. And I took them out and re lined them up about 6 times. I get slightly different results everytime. Am I just not lining them up correctly? It is very hard to see the Notch through the hole in the bolt
Fact , there is only one way to assemble the connecter and that is with the notches lined up with the holes.-Fact, there is no adjustment that can be made at the brass connecter.----Was the philipps screw on the gearcase removed to drain the oil on this motor by any chance?
aschaaf
Ok that makes since. I just bought the motor so I am not sure if it was. What are you thinking could be with the drain plug?
That philips screw is often removed by folks who think it is the drain screw !----------The fact is that it is the pivot pin for the shift fork.------The drain screw is in the front bottom of the lower unit.-----------Perhaps ask the previous owner .
aschaaf
So let's say it was removed. The screw head looks worn like it has been removed. What now?
Perhaps it was not put back in correctly. I am not standing beside the motor, it is difficult for me to trouble shoot / diagnose what needs to be done next.
aschaaf
I understand I'm just trying to get ideas on what I should try next because I am brand new at this. Your guys advice has already helped me in understanding how things work so much better then I did before.
How big of a job is removing the lower unit to inspect if everything is connected correctly? Is it just a matter of draining the oil and removing the the bolts from around the outside, disconnecting the lower shift rod from the connector, and pulling it apart?
