1959 Johnson Seahorse fuel line routing
Sparky54
I have a 1959 Model FD-13 R 18 HP Seahorse outboard motor with the fuel lines disintegrated and in parts in the base of the engine shroud. This is a dual line pressurized tank system. I assume the line from the vacuum side of the engine goes to the right fitting and the line to the fuel filter goes to the left. The lines look like they will cross as they come through the opening on the bottom of the housing. It is fuel and I would prefer not to guess without checking with you guys.
​Thanks !
Crosbyman
air hose goes to the side air pressure nipple behind the carb the other goes to the carb
