1959 Johnson- need engine part
yorkek
Can you help ?? My boss has me looking for a part for his 1959 Johnson 50 Horsepower V4 engine. If I saying this correctly he needs the wiring harness/ cable assembly - Part Number 377279. He needs both ends of the wiring harness part that came with the engine and came with the boat. Any direction would be greatly appreciated.
wbeaton
Re: 1959 Johnson- need engine part
That part number is NLA. You can either buy a used one or build one. Someone will come along with some marine wrecker sites.
Chris1956
If you are near Ocean County NJ, you can try Trixie's. They have lots of used parts for that fatty!
If you really get stuck, you can make a real simple wiring harness for it. You only need a choke wire, ignition killer wire, starter solenoid wire, and two battery cables. That is if the generator doesn't function.
