krullbeast
Thread starter- Joined
- Dec 13, 2009
- 16
i got it running. it shifts fine and sounds good, but it doesn't pee. the guy i bought it from wouldn't throw in the manual (damnit) and i can't figure out where it is supposed to pee. i had the rabbit ears on with constant flow but it wouldn't circulate water through. i only had it run for 30 seconds at a time just to check the transmission and idle. there's a pretty big hole on the back of the motor where i think it's supposed to pee from, but it looks like it could be an exhaust? anyone know where i should look for the water to come out of? i'll try cleaning the foot intake and see if that helps. any advice is greatly appreciated. thank you iboaters!
