1959 Johnson 5.5hp motor
Goodman 48
I picked up this motor. I had it running in my test barrel was pumping water and ran strong. After a few minutes of running, it suddenly​ died. I tried to restart it but nothing. I tested for spark on both cylinders. No spark at all. Is it possible both coils went out at the same time? I've had one coil go out on another motor but never both at same time. Hope someone can give me some suggestions on what to check. Thanks
Honorary Supreme Mariner
Remove the recoil starter.------Then remove 4 more screws and remove inspection cover to see the coils.
oldboat1
Yeah, the technical explanation is that both old coils are probably busted all to bupkus.
I like to replace the points, condensers and wires too, but your call. As you had it running, cleaning and regapping points might do it for you -- should replace the old impeller, though, as you don't want it to break up and scatter parts in the water passages.
Sounds like it's going to be a good motor. Pictures are good (requires a few posts first, I think -- can always throw in some fish recipes or something).
Welcome to iBoats!
F_R
Agreed, cracked coils are the norm on one of those old motors unless they have already been replaced. Related to that, perhaps somebody has already gone in to deal with them, and failed to reinstall the flywheel properly. Then that resulted in a sheared flywheel key as soon as it was started up---which would result in loss of spark to both cylinders at the same time.
