richard.hatcher87
Thread starter- Joined
- Jun 5, 2012
- 8
recently bought a rich line with a 1959 johnson 18 hp fd 13. it hadnt run in quite some time and my knowledge in this area is very limited. after an in spection of the plugs which were new and new fuel with some sea foam it began to run a bit. the carb looked rather clean for a 50+ year old machine so i assumed it had been gone through already but i went ahead and removed it and took it apart... it was really clean... slapped that sucker back on and fired her up. she didnt run real good but i adjusted the lean rich and fast idle screw to the point where it will idle and run. took it on a maiden voyage and she ran good. i dont believe i am getting up to the needed wot 4500 rpm rang though. itll get close and then just bog down??? any ideas? id like a real detailed desription of how to properly adjust the lean rich and fast idle screws. she doesnt get very good fuel enconomy either... im lucky if a 6 gal tank will take me 5 or 6 miles. any hints or tips??? theres not too many vintage engine service marines around here so its all diy hahaha. thanks!
