1959 Evinrude Starflite 50hp V4
jddurst22
My grandfather recently gifted me his old boat and motor that have sat in his driveway, under a tree, for at least 30 years. The motor appears to be a 1959 Evinrude Starflite 50 hp in halfway decent shape. This is my first boat, project, engine rebuild, etc., and I've already learned a lot from cruising the forums here. Figured I'd open a line and keep you guys abreast of the process and ask for any tips and tricks.
Thanks
Jon
jddurst22
I have a question to start.
Does anyone know where I can find the model/serial number on this old motor? I can't seem to find a plate like later Johnson/Evinrude models have.
jbuote
Not sure, but might be on a round disc somewhere on the powerhead.. About the size of a quarter.. Resembles a freeze plug.
​Somebody will probably know for sure and let you know where to look, but maybe look for one of those in the mean time? LOL
Up above the transom clamps should be a plate with that info.-------They are a smooth running motor.-----Simple motor.----But talk about a thirsty machine.----Use fuel as if you had an oil well in the backyard !
oldboat1
Just an observation. It looks like Grandpa might have converted it to a longshaft. Based on the pic you supplied, it LOOKS to me like a short shaft (regular shaft) might fit better on that hull. (I think the antivent plate would be at the bottom of the hull if the extension was removed.) On assumption it was converted, might check to see if the shorter driveshaft is around somewhere.
Yes the (in)famous Fat-Fifty. That motor was used as a sort of a prototype for all the 90* V4 motors that followed. It was only manufactured in 1958 and 1958. Very good running and reliable.
The gearcases (shift dog mostly) were the weak point. The shift linkage would wear and get sloppy. This kept the shift dog from engaging the gears correctly, causing them to round off the dog ears. This caused the motor to slip out of gear with a large bang, at speed.
The other issue was that they did not recycle fuel that was unburned by the motor. Any liquid fuel/oil in the crankcase was dumped overboard. Sometimes, it could be as much as 1/3 of the fuel used. maye sure you adjust the carb accurately to limit this discharge. The motor will have high and low speed dual needle adjustments.
The model number will be something like V4SL...
Best of luck...
It was marketed as a 50 hp in 58 / 59.---That block was still used in the V-4 60 hp in the mid 1960's.--A simple tough machine.
Joe Reeves
List the model number when you find it. Small plate on port transom.... larger plate, center front of engine, just above transom area.... quarter size core plug on power-head.
The carburetor will most likely require cleaning... BUT... try it first, you may be lucky.
Points: Set on high lobe so that a .020 gauge clears... and a .022 will not.
S/Plugs: Champion J4C or J6C gaped at .030 . I suggest/recommend the J6C.
Gear-lube: HiVis (Available at dealer, WalMart, Marine stores, etc). Fill from bottom large slotted screw until lube exits top identical screw. DO NOT EVER remove the philips screw you see in the lower unit skeg! (Shift Lever Shoulder Pivot Screw).
(Carburetor Adjustments - Older V/4 Downdraft Carb)
(J. Reeves)
NOTE: The early model downdraft carburetors incorporated "Adjustable High Speed Jets". The later model downdraft carburetors used "Fixed High Speed Jets". The high speed jets would be located in back of the two bottom drain screws. Follow the below instructions accordingly.
NOTE: If you do not have adjustable high speed jets, ignore those paragraphs pertaining to same...... BUT do make sure that you manually inspect and clean the two brass fixed high speed jets which would be located in back of the two 7/16" slotted hex head bolts in the bottom front portion of the float chamber.
Lift the center High Speed Control lever and turn it so that the point faces forward, resting on the high ridge. This will disengage the lever control gear from the individual high speed jets (slots). Have the slow speed needle valve knobs installed upside down so that they can be turned without encountering any obstruction.
Gently seat each of the High Speed needle valves, then back each one out one (1) turn. Gently seat each of the Slow Speed needle valves, then back each one out one and one half (1-1/2) turns. NOTE... have the jam nut on the s/speed needles snug so that vibration won't have any effect on them, but loose enough so that you can turn them without a great amount of effort.
(High Speed)
With a reliable person at the wheel, and one kneeling in front of the engine, start the engine (yes, it will run lousy with the above initial needle valve settings), put it into forward gear, and apply full throttle. Start with the High Speed adjustment on the left using a screwdriver that properly fits the slot.
(High Speed Adjustments)
At full throttle, with the proper size screwdriver, slowly start turning one of the H/S needles in segments of 1/8 turn, waiting momentarily for the engine to respond, then repeat turning. You will reach a point where the engine will start to die out. At that point, back that needle valve out approximately 1/4 turn. Now, go to the other High Speed needle valve and repeat that procedure. At some point in that 1/4 turn out, you will find the smoothest high speed setting (you can now lower the throttle rpm). That will have both high speed needle valves set correctly, and at that point you can lift that center lever adjustment of that high ridge, keeping it lifted until the point is facing the engine, then lower it into its proper position. (When you turn that lever now, you're adjusting both High Speed needle valves at the same time.)
(Slow Speed Adjustments)
Now, lowering the rpms of course, take the engine out of gear and set the throttle just to where the engine will stay running. Again, in segments of 1/8 turn, slowly start turning in one of the slow speed needle valves, waiting a few seconds between each turning for the engine to respond. As you turn the s/speed needles in, the rpms will increase..... and as it does, lower the rpms to where the engine will just stay running (otherwise the rpms will climb quite high). You will reach a point whereas the engine will either start to die out or it will spit back (sounds like a mild backfire). At that point, back the needle valve out 1/4 turn. Repeat the process with the remaining slow speed needle. Again, at some point in that 1/4 turn out, you will find the smoothest setting. When finished, tighten the jam nut somewhat, then remove and reinstall the s/speed knobs correctly (right side up).
