1959 Evinrude cowling change.
Sporgo@gmail.com
I have a 1959 18 hp motor with the bread box style cowling. Beisdes the adjustment needle positions being all wrong is it possible to install the earlier cowling onto the later motors?
In my case it is not purely for aesthetics the bread box creates problems by bumping into the well on my sailboat and limiting turning radius.
oldboat1
That's a tough one. The earlier metal cowlings are just as beefy, I think. A '61 is more sleek, but don't think it would fit your pan.
If open to a replacement motor: The Chrysler/Force 15s are lower profile motors, and might be worth a look. I've had good success with a number of Chryslers (had the 15, but never got to use it before selling it).
[edit. not thinking..... '70s to '90s J/E, 9.9 or 15. '60s/'70s low profile 9.5s.]
Chinewalker
Any of the 1959 or later cowlings a will fit IF you swap the belly pan, too. They all use the same base mounting brackets. You cannot use the earlier all metal cowlings, as the bosses on the head and starter mounts are gone. And you can't swap an earlier cylinder head on there, either, as the '59 and later heads have thermostats in them.
Sporgo@gmail.com
By bosses you are referring to missing mounting brackets, correct? Perhaps something could be fabricated to make it possible. Those two sharp corners that stick so far out on the front of the 59 box are the issue. The aesthetic improvement would also be considerable.
Chinewalker
You can remove the belly pan and replace it with the original style to whatever cowling you go with. Best if you start with a parts motor that has the parts you want, .ie if you like the 1957 cowling, find a junked 1957 with cowling and lower pan pieces. It's pretty major surgery, but not difficult. You can also swap the recoil starter mounting brackets, which will give you cowling mounts at the front. Then you can figure something out for the rear. Not impossible, just a matter of how much time and effort do you want to put into it.
