1959 Evinrude 5.5 Tilt Lever issue...
Simonw
We'll it could be an issue with the newbie owner too. First hi to every, looks like there is a lot of great info to take in from this forum. Secondly I am first time boat owner so please be gentle. So I bought a 12' aluminum boat that came with a 59 Evinrude 5.5 hp. Looks to have minimum hours or it's just that clean. I am trying to tilt the motor by first putting the little lever from locked to released, then I pulled the tilt lever up but the bar stops short of clearing the slot. The bar is being stopped by hook shaped arms. Is there a trick to tilting this motor. I am usually pretty good at figure these things out but am stumped. Appreciate any help and advise. Simon
F_R
Honorary Supreme Mariner
1. Put the release lever on the front of the motor in the released position.
2. Tilt the motor. That's all there is to it.
3. The tilt angle adjusting pin that you are trying to move can only be moved once the motor is tilted.
pro-crastinator
No Title
Here's a "bent" version of your lever.
(It straightened out nicely)
Tilt angle adjusting pin underneath - low -
Simonw
Thanks for the input so far. I tried again but the adjusting pin is certainly not disengaging fully. Maybe I will take a picture later. Thanks.
Simonw
thank you all. its sorted out. yes you guessed it, it was my own stupitity.
