1959 evinrude 5.5 carb float?
bo7348
Hello, i pulled the carb from my evinrude to put my new carb kit in, the kit did not include the float, i see that there are a couple replacement ones on ebay but they are still cork, was wondering if anyone knew the part number for the new plastic one, there is only a few different floats for sale on ebay, but they do look very similar to the fit of the cork style, im thinking that they are all basically the same, can anyone confirm this?
sutor623
Re: 1959 evinrude 5.5 carb float?
How does the current float look?
1946Zephyr
You can probably look into a float for a later 6hp Evinrude. Those should mostly be plastic and the carb should be pretty close to the same size and all.
F_R
Easy. 375919 cork float is obsolete, and is replaced by 396514 Nitrophyl (SP?) float. You have to get it from an Evinrude dealer, or somebody that sells genuine Evinrude parts.
EDIT: Nitrophyl is that black plastic stuff that Ethanol won't attack.
bo7348
Thanks for your help, the cork float fell to pieces when i touched it, i called my local evinrude dealer an they had it... Is there anything on this little motor that is restricting power or anything, i plan to fix everything while it is apart..
1946Zephyr
Oh boy, I never seen one that bad. Yea, it looks like a carb rebuild is definately in order. You might check the ignition system and make sure the coils are in good condition and no cracks. Those are good little motors and are pretty easy to coax back to life. I have a '58 Fisherman, myself, but it's going to need some of my TLC.
bo7348
well, i have installed a new carb kit with float, head gasket, spark plugs and wires, and new points and all i can get is a sputter every now and then, i set the points to .020 and have very good spark on both cylinders.. when i had it at my dads shop i didnt have a pull rope so the compression test was low, it would jump up to close to 30 just but spinning it by hand... so it seems if i did a full compression test the numbers would continue to jump... this thing wont start at all.. any suggestions?
Joe Reeves
Double check your work! Spark plugs should be Champion J6C plugs, gapped at .030 .
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
(Carburetor Float Setting)
(J. Reeves)
With the carburetor body held upside down, the float being viewed from the side, adjust the float so that the free end of the float (the end opposite the hinge pin) is ever so slightly higher (just ever so slightly off level) than the other end. And when viewed from the end, make sure it is not cocked.
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubbing portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
