1959 35 hp evinrude lark
Johnson110
I just purchased this motor, the motor would only turn a little bit I found a bolt on the steering column and removed it the motor now turn freely, what is this bolt for? it on the top part of the column to the left,
gm280
Sounds like the tension adjustment, but honestly without more info and/or pictures that is merely an uneducated guess...
Chinewalker
Leave the bolt in there, but adjust the tension on it to allow for turning.
Johnson110
Thanks, I have a 1960 18hp evinrude with a tiller handle on it, I was wandering if I could take it off and use it on the 1959 35hp lark evinrude?
boobie
All you can do is compare both motors in the mounting area and see if it will work.
Johnson110
Thanks, if I wanted to hook this steering to a teleflex steering, which I found a 14ft mckee craft has what do you need to hook it up to the engine, it just has the end of the telefex cable going to motor.
