I assume you took the impeller housing and such off now?
{Put a drop of oil on the end, to aid in not damaging the drive shaft seal. Slide it in past the seal, until it hits the pinion. Rotate and it should drop into pinion.
Then pus stainless impeller housing plate back on. Seal it down to the casting with thin bead of 3m 847. Put in impeller key in shaft. Drop impeller onto the key. Now is a good time to replace impeller. Put a little grease or dish soap on the blades of the impeller. Drop housing onto impeller, push down while rotating shaft clockwise. Put OMC gasket sealing compound on threads of impeller housing bolts before installing.
regrease the splines of the drive shaft, and install new o ring. Dont get grease on the TOP of the shaft, just the splines. Add grease to the impeller housing grommet (ensure it is in good condition, not stretched or swollen). Also add grease to the end of the water line sticking out of the bottom of the motor.
Now it is ready to bolt back up to the motor.
