1959 18hp aftermarket starter wiring help
prsman23
I've got a 59 evinrude 18hp fastwin. Appears to have a non OEM electric start. I don't see a starter solenoid in the case. Does it need one? Also, there are 5 wires, three of which I have no idea what they are for.
2 of these 3 are capped so I would assume nothing. The third is loose.
Of the two that are hooked up, one goes to the starter and the other is grounded.
I'll upload pictures in the morning when I'm not on my phone. Storms have my home internet out :-(
F_R
Honorary Supreme Mariner
Yes, it needs a start solenoid. It normally is in a separate junction box mounted in the boat. Due to unavailability or cost, most people rig up their own design.
BTW, we all hope the storm is over and you don't have property damage.
ssdale
Starmada Splash of the Year 2016
Look At the sticky at the top of this forum called "Top Secret Files". Open and you will find your wiring diagram or one similar. It will start to make sense. On my Lark II, the extra wires were for an optional generator. I think the solenoid is the same as Ford used on a lot of their 1960's cars, or mine was. Cheap and plentiful.
Be careful to not energize the black coil wires as they will be instantly ruined. Google images or search ebay for evinrude starter boxes to see an original setup. Its hard to put something together without ever seeing it. Good luck!
Dale
prsman23
Thank you both very much!
That really helped. I took a look in the back of the boat and sure enough it was there... Concealed nicely. The storm passed without incident and the internet is back up!
Wish I would have found the top secret files earlier. I do appreciate both members guidance. Thanks for being patient with a newbie.
(The middle wire doesn't have anything going to it. I thought that was odd since someone took the time to solder a connector to it...)
HighTrim
If you haven't found a wiring diagram, PM me with your email and Ill send you one.
silver_bay
If you have the "male" plug inside the engine, the fat pins are the starter, the one between them is the choke (do you have the choke solenoid?) and the other two go to the points (shorted together to kill the engine). In the late sixties/early seventies the solenoid was moved inside the engine cover, and another pin was added to activate the solenoid (and the fat red wire went directly to battery plus).
You can buy a reproduction harness from nymarine dot ca for $$$CA (which is still $$US). I've been working on figuring out how to mold a new harness for MY 1959 Fastwin.....
The hole where the plug goes is the kill button on a non-electric. If you're going to be operating it from the tiller, you can put a start button in the engine pan, and mount the solenoid inside. Then all you need going into the engine is power from the battery.
I remember somewhere, someone said they connected a heavy duty electric appliance cord/plug (for a dryer or stove), and mounted a matching outlet at the battery box!
silver_bay
