1959 10 HP Golden Jubilee Needle
mtweaver
I have a 1959 10 hp golden jubilee. Rebuilding the carb. The top mixture screw or low speed screw when removed has an aluminum plug or spacer that came out with the mixture needle. The needle threads into it. Now I don't know how to replace it. If I turn the mixture screw in it threads the spacer out and you have no idea weather your needle is seating or not. What am I doing wrong, anyone know what to do?
GA_Boater
mtweaver Welcome and this is your new thread after moving the post out of an old one.
Please read the Help Tip on top of the page.
F_R
Honorary Supreme Mariner
Start by slipping the packings onto the needle. Then start that threaded part onto the needle a few turns. Then push it into the carburetor until it bottoms out. Follow with the packing nut and tighten it enough to hold the packings and threaded insert in place. That will prevent the insert from spinning or moving. Now you can screw the needle on in until it lightly seats, then back it off the preliminary 1-1/2 turns. After final adjustment, tighten packing nut enough to prevent unwanted needle rotation.
