Re: 1958 V-4 Starflite 50hp
Mix up some fuel. One quart of TCW-3 rated outboard oil to six gallons of 87 octane gas.<br /><br />Try to start it.<br /><br />Once started, check for water spay out of the exhaust relief port which is located mid way up the leg. While running check the temperature of the engine by placing your hand on the top cylinder heads. If you can't hold your hand there, it's overheating-SHUT IT DOWN.<br /><br />If it runs OK, I would replace the water pump impeller, before I took it out on the water.<br /><br />If it does not run OK, you're probably in for a carb rebuild, at a minimum. Not expensive.<br /><br />I owned one of those.<br /><br />Be prepared, it is a gas guzzling beast.
