1958 Rude 10 hp Iboats sell?
kodibass
Master Chief Petty Officer
Does iboats sell the flywheel key for a 1958 rude 10 hp mod# 10016 ? I think the part# is 120395 but having no luck finding it, I would much appreciate it.
F_R
Honorary Supreme Mariner
Re: 1958 Rude 10 hp Iboats sell?
It is a special key, so you have to get it from an Evinrude dealer, or at least somebody selling genuine OMC parts. Should be no problem.
kodibass
Thanks! yep got'em coming I kinda have made it a promise to myself to try and buy from Iboats as much as I can. But I don't know if its just me or what But I seem to have a bit of trouble using the search bar, mostly because I don't know the correct item name or part# etc. getting beter tho. cheers
kodibass
Thanks' kfa4303 That will help lots Yep Ill post photos as I go along.
Pilot54
you can use any steering wheel puller, after that you tie the screws up and the center screw as well, you have to hit the center screw , not too stronge and the flywheel will release.
In Canada you can rent it for 24 H for free from Canadian tire.pulley_stock_puller.jpg
wilde1j
Wrong ... that's a HARMONIC BALANCER puller and they're cheap (<$20).
