1958 rde-19c Seahorse 35
Mr. Bradish
I am reviving a 1958 Johnson RDE-19C. The forums have been a great source of info. The unit was going to the dump unless I wanted it..:) So far I've replaced the coils and serviced the carburetor. Compression is very good and I started it for the first time yesterday... I find the cylinder head has been replaced by a later model with thermostat housing on top. The housing hits the cowl when closed. Anyone else encounter this and what's the fix? Replace the head? Also the cowl seal is missing. Will replacing the seal raise the cowl enough for clearance? Thanks in advance.....
kfa4303
Banned
Re: 1958 rde-19c Seahorse 35
Hi Mr. Bradish. Welcome to iboats. Great old motor you've got there. Hopefully, I'll have one just like it one day. Can you look on the new/replacement head for a parts number, or post a pic of the modification as it is? If you're worried about the modification, you can find a '58 replacement head and return it to its factory spec. Ebay.com, marineengine.com and aomci.org are all great places to look for parts. If you're lucky, replacing the cowl gasket will raise the cowl enough and prevent it from contacting the t-stat housing on the replacement head. The actual gasket can be found at Nymarine.com, but they're a little pricey. If you don't feel like spending that much, you can use a piece of standard fuel line and slice it down the center to serve as the gasket instead. In the meantime here are some great links to keep your "Big Twin" running for another 50+ years.
http://www.duckworksmagazine.com/04/s/columns/max/24/index.cfm
http://www.marineengine.com/parts/v...ntage-evinrude-johnson/377517/37751700001.htm
HighTrim
Just to note, it is www.nymarine.ca
What does the number on the welch plug on the powerhead say?
You may have a RDS20 head, which is the '58 Super Seahorse, it had the t stat factory
Mr. Bradish
Thanks for the information. With the cowl installed, the gap at the front is about 1/4 inch and the gap at the rear is about 1/2 inch. The casting numbers on the blue head are 307306 and 307759. The symbol next to the number looks like a"M" The second picture shows a starter solenoid and fuel pump that were added. Compression release parts are missing. IMG_0578.jpgIMG_0580.jpg.
Mr. Bradish
I'm still learning. What is a welch plug? The picture shows numbers on the face of the head. IMG_0583.jpg
kfa4303
Banned
Hello again Mr. Bradish. Looks like you definitely have a "Franken-Rude" (Johnson-Evinrude hybrid) on your hands. If the motor didn't come from the factory with a t-stat, you don't "need" one. As a result, it may be easier to remove the current head and replace it with one that is more correct. That should also eliminate any issues you're having with the cowl not seating properly. Thankfully, replacing the head isn't very expensive, or difficult, but you do need to take care not to break any of the head bolts. The Welch plug is a silver colored, quarter-sized metal disc in the engine block with an ID number stamped into it.
Mr. Bradish
Thanks for all the help. I'll keep an eye out for a head. The welch plug on top just behind the thermostat housing is number 1725126 with a Johnson symbol. The cowl seal seems a little pricey but I can't seem to find it anywhere else ... yet
kfa4303
Banned
check ebay.com, marineengine.com and aomci.org for a replacement head. Unfortunately, the gaskets are ridiculously expensive as are the decals :/ I just use a few pieces of fuel hose with a slit down the length to act as a gasket, but it's not quite as pretty as the real thing.
Chinewalker
That head is likely off a 1960s Evinrude 33hp Ski Twin. They were the same displacement as the older 35s, but did away with the compression release and added the t-stat. Functionally, it works, but it lacks the cowling supports. There is nothing there to secure the cowling and prevent it from lifting up from the rear.
I have a spare '57 35hp cylinder head - if interested drop me a PM...
