PhilfromOhio
Thread starter- Joined
- Feb 7, 2010
- 82
I have a question for anyone with experience with the oldies? I have a repair manual, it is a good one, very detailed, and a parts manual, also very detailed. However it, it being both the repair and parts manual, only show how and what to gap the points at .20, no problem, ...How do I get that plate off the pulley? there are three small screws and that removes the cover, and there is a small window that you can see the points, but you cant remove them, it's too small, is this the point where i need a flywheel puller? I unbolted the nut ontop, but the cap wont budge? HELP aaahhhh!!
I had great spark and it was starting every pull, pull because the starter only spins, the worm gear isnt pushing the bendex up to the main gear? another problem to fix, But now, no spark, just enough to get it to mumble. I will be putting new element inside the dizzy cap, the plugs are new, and the wires are new? Everytime I squeeze a bit of light sandpaper over the points it fires up, but not for long? I really need to replace the points, just cant access them?
