1958 Johnson Seahorse FD-12 18 hp
antlers1
Does anyone know how to repair, if even possible, the eccentric screw on the armature plate. Just picked up a 1958 FD-12 in failrly good shape and was performing a tune-up and was in the process of adjusting the point gap and the eccentric screw twisted off.....ugh. Is it possible to replace the screw or do I need to start looking for a used aramture plate? Any help would be greatly appreciate. Thanks
HighTrim
Re: 1958 Johnson Seahorse FD-12 18 hp
It snapped in half? Is if flush with the mag plate, nothing sticking out you can grab onto or cut a slot into with a dremel? May get lucky with a left hand drill bit.
antlers1
The screw snapped in half. The bottom portion is still in hole. Is flush or might even be recessed a bit. I realize you can get a replacement but how do I get this broken piece out. I guess I don't understand how this screww works. I know it has threads so I don't want to mess up any threads. I checked and the replacement screw is 11.00 but I can get a used plate for 20.00. This has never happened to me before so I'm a bit perplexed. Thanks
F_R
Honorary Supreme Mariner
Let's just assume the eccentric screw didn't break because it is corroded in the hole and wouldn't turn at all.
As you know, the screw is threaded. As installed, it is turned all the way in, then backed off far enough to allow back and forth rotation to move the breaker base. What happened is that yours was run in all the way and not backed off. So when you attempted to turn it a bit more to adjust the breaker, you snapped it off.
It should be easy to remove the broken piece if you can just get ahold of it somehow. I suggest removing the armature plate and attack the screw from the bottom end with a small drill bit. The bit probably will zip it right out. However, forget it if it is broken because it is sized in the hole from corrosion.
If all else fails, you don't really need that screw. It doesn't do a darned thing except make it easy to set the points. Once they are set, the eccentric does nothing at all. What I'm saying is move the breaker base manually to get the gap setting and let it go at that.
antlers1
Thanks so much for explaining this. Now this make sense. I dont think I can grab it from top but i will take the plate off and if all else try from bottom but sounds like that is really not necessary if i can get the base adjusted correctly. Actually, I was thinking of running a small self tapping screw in the hole just to lock down base after I adjusted it. Thanks for the help.
HighTrim
As Frank stated, it doesnt lock anything, simply makes it easier to adjust. Forget about the tapping screw.
antlers1
Frank and Chris, thanks for your help. I will follow your advice. Bill
