Could be many things, but cracked coils are a common issue on this motor. A motor that age you should really pull the flywheel and replace the coils, points, plug wires and plugs.
I have the exact same motor, except it's a '57. It's a barn find, looks like brand new under the cowling so I'm assuming it's all original. Verified compression before I bought it so before I even start it or put in on a boat I'm going to pull the flywheel and replace all the ignition components, rebuild the carb and replace the water pump impeller. Lot's of great posts here by the "experts" on how to do all this, just do a search and you will find everything you ever wanted to know about this motor and then some!
Good luck and welcome aboard to the best boating forum on the web.
