1958 Johnny 10 hp deal?
lindy46
Re: 1958 Johnny 10 hp deal?
Does it come with the pressure tank? What has been done to the motor? New ignition parts? Carb been rebuilt? Lower unit pressure tested and leak-free? New water pump impeller? Does it have good compression and run good? If you can answer "yes" to all the above, and the seller can document the work was done, then it may be a good deal. A motor of that vintage in unknown condition (but with good compression) would be worth no more than $100 to me.
CheapboatKev
Thanks for the comments Lindy..
Since he converted to run on a single hose, I thought that meant you didnt need a pressurized tank.
This guy tinkers with OB and has one on CL every 3 months or so.
States it runs excellent, no leaks..
I wont be able to see it in person till tomorrow though.
lindy46
If he's converted it to a fuel pump, you won't need a pressure tank.
