Hello everyone, I picked up a fat fifty and have been going though it. Compression check, 90 90 90 87,new water pump, plugs, rebuilt mag, cleand carb,did link and sync. put it in my drum of water and fired it up. seemed a little rough but not terrible. was having trouble with idle but figured i would go back to it. took it to the lake for a short test and under load it had no power. While idling puled spark plug wires one at a time. Pulling right side wires one at a time would kill engine. pulling left side had no effect on idle. And they are working because both leads lit me up. Got home and checked for spark and its great. put back in water barrel and started again. Still dead on port side. As it ran put hand over left side of carb and has great suction and killed engine if i blocked it off. When i did this to right side of carb no change, kept running, put a little fuel down left carb hole and engine died, put it down right, no change. Pulled carb again and everything looks great. Did float level by the book. Pulled read valve plate off, lookes great. Sorry for the long post but i am baffled. Please give me a direction to go.
Thank You, Steve
Thank You, Steve
