Re: 1958 evinrude lark 35hp
Well, it wouldn't make sence to set the cavitation plate above the keel, when the manufacturers of the boats build them to take short shaft motors that would put the cavitation below, now would it? The people who build these things know what a short shaft motor length is and how tall to build the transome. If your cavitation plate is not setting right with the keel of the boat, then you might need to do some research on your boat and find out exactly what motor is intended for it. If your boat is infact a 1958 model, then you can pretty well guess that the motors of that year and size should be explored to kit up to it. If a boat is in it's 50+ year age, then I would lean towards the lower end of the horsepower rating, just so you don't gun it on a nice day in the lake, and end up with the transome coming off the boat.:facepalm:
