squirrelsurf69
Thread starter- Joined
- Mar 10, 2010
- 3
Ok. I recently bought a boat with a 1958 Evinrude 35ph Big Twin. the serial number is 25936-03899. I was first wondering what the second part of the serial number meant? The previous owner said the engine ran great, but was then stored for 2 years outside. When I asked him to start it he tried, but nothing happened. I realize you may think I should have walked away, but i got a great deal, and figured I could repair it, or buy a new engine.
Here is the problem:
When the previous owner went to start it, he turned the key, and all I heard was a click (at the starter solenoid). I took it home, and began to inspect it. My voltmeter showed 11.5 volts at the battery, and 11.5 volts at the starter solenoid. It also showed 11.5 volts across the starter solenoid when I tried to start it. I measured the voltage at the starter, and got 5.6 volts. Does this indicate a bad potion of wiring from the solenoid to the starter? The engine was a bit dirty, and some of the wires were a little frayed, NOT inlcuding the wire that ran to the starter, or its ground.
I removed the starter, and was going to test it by hooking it directly to the battery to see if it would spin. When I did nothing happened accept a drop in voltage from the battery from 11.5 to 6 volts. The starter was slightly warm as well. When I disconnected it, the battery read 9 volts. Was that a stupid way to test the starter? Why did it suck so much juice from the battery? Does the starter need a certain voltage to even spin up?
The engine also has a pull start, but it is not smooth, and is somewhat difficult to pull. It is jerky. Any ideas why?I can pull it all the way, and each time it seems a little bit easier. I don't mind pull starting it every time, but can get it going that way either. Plus an electric start would be awesome. Any help would be greatly appreciated.
My guess is that the starter is bad, and maybe some
