1958 evinrude 18 fastwin carb issues
Tater89
Hello everyone, I'm new so forgive me if I screw something up. I have an 18 hp fastwin that is leaking fuel out of the air box/carb intake. When I prime my fuel bulb fuel comes out of the carb like crazy. I have rebuilt the carb completely with the full kit. My float still floats. The ignition/electrical is all new. I have compression. I'm at a loss as to why this thing won't stay running for more than 20 seconds and is leaking fuel. Any and all advice and ideas are appreciated.
gm280
Well :welcome: aboard Tater89 to iboats. WE always like new members to join us...
It sounds like you still have a carb issue to me. Seems like the needle and seat are not working to close off the fuel coming in when the fuel bowl is filed. So I think you need to disassembly the carb again and verify it works. Not knowing your particular carb or any of the setups, the usual way to set float levels is to set the float level with the carb top. Then turn the carb over and see if it will open the needle and close when you turn it upside down. Once you verify that, then see if it will work on the engine. JMHO!
Tater89
Thank you gm280! I'll try that this evening and see if it works. I wouldn't have gotten this far on it if it wasn't for the I boats forums and people like you that take the time to help others out. Thanks again, I'll let you know when I try it.
HighTrim
Everyones idea of carb cleaned and rebuilt very wildly.
For some reason, the needle is not seating. Either debris in the seat (did you change needle/seat?), float catching on the bowl gasket, vent clogged, float not floating, float setting wrong, etc...
I like the unhinged end, just slightly higher, than the hinged end, and level. This ensure the needle fully seats when the bowl fills.
