shipwreck
Thread starter- Joined
- Nov 23, 2006
- 263
1958 5.5 evinrude model 5516- hard to start
compression low 60 psi cold on both - i had 3 other motors like this low compression , never had this problem
Will start full choke 5-6 pulls with the throttle turn up a good bit more than halfway ----dose not like to run slow /shift or start area of the tiller handle.
Stop the motor AND CAN'T GET RESTARTED.Crab rebuilt -needle set 1.5 turns low 3/4 high -points condenser new, coils good have spark on both cylinders.
I PULLED THE POWER HAD OFF TODAY AND i found a missing seal #303391 and o ring missing THAT SIT under bottom of engine that ride on top of driveshaft ( there is spring , a cork gakest and sliver plate)
but missing the seal and o-ring.
what do think?
i think this is problem -anyone- other ideas everything else has been checked
what do think?
