MN_fisherman
Thread starter- Joined
- Mar 4, 2008
- 21
I have a 57 Gale 3hp and the original cork float is deteriorated I believe I heard someone mention here that the mercury floats (Sierra 18-7208 Float) can be modified to work in the gale carbs. I can't locate the old post but I'm wondering if there is someone here that has experience with this substitute and can tell me what is involved in making the mercury float work.
Also I'm wondering if there is a source of the packing that holds the main throttle neelde in place I think I can reuse the old one but I thought I would ask if a modern replacement is available since I have the carb apart already.
Finally can anyone tell me if the OMC filter bowl gaskets (Sierra 18-2889 or
Sierra 18-2892) will work to replace the original gale gasket? I know the gale carbs are completely different but I wondered if anyone has every tried to use the OMC gaskets or if another substitute exists. Its not as critical because I think I could probably just make my own from some gasket material.
Anyones input or experience will be appreciated!
