1957 johnson5.5 hp vs 1964 evinrude 5.5hp
whytimmywhy
I have both and the johnson is far better looking, can I use parts from the evinrude on the johnson?
F_R
Honorary Supreme Mariner
Some of them, yes. Most of them no. There are many obvious differences because of the years.
Chinewalker
Lower units & clamp brackets swap around. Exhaust housings may. Recoils interchange. Tillers interchange. Crankshaft and internals should. Blocks & cylinder heads will not. Carbs will, with some parts swapping for choke linkages.
