jjohson1957
Thread starter- Joined
- Aug 17, 2017
- 2
Any Help Appreciated!
I am just digging into my outboards because i am restoring a 1957 Cadillac aluminum boat and the boat is coming along nicely and i wanted to make sure one of these 35hp would serve me well. Last night i picked up a compression tester from oreilys to test. The way ive been doing it is i have a jump starter box that acts almost like a key i can hook it up and turn the knob and spin the starter seems to work fine. So i made sure it was moving freely with a few pulls of the chord and put the power to it. 120 psi on the top cylinder that seemed pretty good to me. So i switched the tester to the bottom cylinder and now the fly wheel will make a full revolution and hit hard. it wont budge it will go both directions what seems to be a full rotation. Did i bump the shifter? i can spin the prop freely in both directions. It spun prob 15 times while checking the top cylinder no problem. I was thinking of removing the lower end just to eliminate the possibility of the gears being messed up and locking it like that. I have to take it off anyways to maintenance its been sitting prob 10 years.
Questions.
120 PSI on a 1957 outboard is good correct? If its that way on both cylinders i wonder if previous owner had it rebuilt.
Does it sound logical that hard stop on the flywheel is from the gears? Maybe being a little off? Sticking? Anything easier i could check before pull the lower unit off?
Thanks for any help!
Questions.
