Re: 1957 johnson 7.5 hp AD-11 lower unit removal - impeller replace
I put the grade 8 hex socket screws back in my 5hp Gale too, with some anti seize. They are a lot easier to turn than a slotted head screw, especially that one that sticks through the water jacket in the rear, it seems to like to rust. If it is like mine, make sure it's the right length screw or it can get against the cylinder wall.
Ended up having to cut the head off of that rear bolt and drilling and tapping it for a new one.
I also has to take the whole transom mount off to get enough leverage to turn the front bolts.
