1957 Johnson 18 Tank
bassmoe
I have a 1957 Johnson 18 that runs awesome. The o-rings in the duel hose fuel connector have deteriorated to the point where the tank will not hold pressure and the fitting leaks at the motor.
Does anyone know where I can find these o-rings? I haven't had any luck matching them up.
lindy46
Re: 1957 Johnson 18 Tank
Not sure if they have them here on Iboats, but a Johnnyrude dealer should have them. Get the factory rings, not aftermarket, and make sure they give you the ones for the old 2-line pressure tank. The newer ones are bigger.
wilde1j
The O rings are definitely available from a BRP Evinrude dealer.
