You can tighten up the tilt bolt. It has a spring behind it that allows for added tension to the tilt. Better yet, carry a stick on a string - tie it to a cleat or handle in the boat so it doesn't get lost. Place the stick crosswise under the swivel bracket when the motor is tilted and lower the motor onto the stick.
On my 56 Big twin, I use the "tension" method when I am tilting the motor up before loading on the trailer - and when its on land, put a 2x4 block in a pinch point to support it for the trip to the garage.
Get a wrench and tighten the bolt so it stays up when you tilt it out of the water.
