1957 Evinrude with a broken connecting rod
NYT
Hi.I have a 57 Evinrude 7.5hp with a broken connecting rod.I did a search but could not find a source for parts.Can anyone tell me if internal engine parts are available for this motor or is it now only good for parts?Thanks.
57chris
Re: 1957 Evinrude with a broken connecting rod
Just about everything is still available for that motor, I see good powerheads on ebay all the time...might want to check there.
samo_ott
If you're talking new, I doubt it is available but someone else will let you know. But usually when a rod goes there is other internal damage. Have you opened it to verify that there is no other damage?
F_R
The 277401 connecting rod is listed as no longer available. Try www.sea-way.com
NYT
I have not split it open yet but I pulled out the piston with the broken conn rod and I can see that the crank journal looks galled up.The piston got nicked up a little on the bottom of the skirt.Can I clean the crank and piston up with emery cloth and put on a new rod?I've done this before with Briggs motors and it worked for me.Also,will a 1954 powerhead fit in a 1957 housing?I see one on Ebay.Thanks.
jbjennings
I'll bet the wrist pin bushing is completely gone. Besides the other huge problems you already mentioned.
Do yourself a favor and get a used powerhead. The 7.5hp powerhead is one of the most common I always used to see on ebay. I don't believe the '54 will work, but I could be wrong. If you really want to give yourself a treat, place a free wanted ad on aomci.org and someone will take care of you----I suspect in just 2 or 3 days you will get a response from one of the members. They're good folks.
Good luck,
JBJ
