1957 Evinrude Big Twin 35 shifting issue
eolsen
Occaisonally when first starting out for the day, the motor after being shifted to forward, would want to creep back towards neutral but it would do this with a slamming motion (not good for gears....). I would have to manually pull on the cable forward towards the boats bow sometimes to make sure it stayed in gear. So about two weeks ago I ordered new throttle and shifting cables the same length as the old ones and installed them. Throttle cable is perfect. Shifting cable worked great at home and when i got on the lake i had nothing but problems. I had to disconnect shifting cable and for the rest of the day i shifted manually without the control box. I tried the adjustment dials at the cable end at motor with no luck either. Any thoughts would be greatly appreciated.
Honorary Supreme Mariner
This is a fairly common issue with these motors.----It is how many years old ??----Worked on by different folks over those years.----Start by removing the window on the side of the exhaust housing.----The connecter for the shift rod is there.---Any up and down motion / free play there ?---Possibly the clutch dog and forward gear are worn as well.---Not hard to check it all out for repairs.
eolsen
There is no play up or down through the exhaust window. If I don't use the control box n cable and just shift manually on the motor I don't have the problem. Wouldn't that tell me the clutch dog and forward gear aren't worn?
Any additional thoughts? It usually only occurs in the first couple minutes then I don't experience it for the rest of the day.
