Hi all, I recently picked up a 1957 Evinrude 3hp (model 3022) for about 50 dollars. I'm using the motor on a small 12 1/2 foot fiberglass boat (weighs about 100lbs). I cleaned out the gas tank, replaced the plugs, cleaned the fuel filter and blew out the fuel line. I also noticed that someone didn't put the low speed carb adjustment back on correctly. When it was at the hard stop it was still open (at least one full turn). So I removed the nob, closed it and put the knob back on so the hard stop means it's closed. Prior to this, it would not run at the slow speed.
Now the issues. When using the motor at home, in a trash can full of water, the motor runs and seems to run well, but both carb adjustments are completely closed. In slow speed, if I open the slow carb adjustment, it sputters and tries to die. The same thing happens with high speed.
As expected if you close the fuel valve the motor will, after 30 seconds or so, shutoff.
Now at the lake it's a different story. I must make the proper carb adjustments in order for the motor to run. If I attempt to close them the motor will sputter and start to die. Also at the lake while at full throttle, if I rock the boat back and forth (not hard just adjusting myself in my seat), the motor will sputter start to die. It also seems to struggle at times (turning, riding over small waves, rocking a little back and forth). Lastly, at the end of my trip, I closed the fuel line and the motor didn't shut off. I ran it for several minutes and it didn't die. It also leaks fuel if you lay it on it's back or side.
I haven't done a compression check yet, but I plan one very soon.
I have read through a couple posts in the secret file, but since I know very little about small engines I didn't know quite where to look.
Any suggestions, thanks.
matchbx
matchbx
