Hillbillywill
Thread starter- Joined
- Feb 18, 2011
- 26
1957 evinrude 18 hp tiller.
Did tune up and runs great.
Problem: put tiller in ?start position? pull cord and the tiller grip and ignition plate immediately rotates back to the ?stop position?. Thus, I can only get the dang thing started if someone stands there and holds the grip in the start position while I crank it. it has killer compression and my right arm looks like pop-eye?s. and if I let the throttle grip go freely it immediately rotates to the stop position and dies.
So, is there any way to tighten up the rotation of the ignition plate? I pulled the flywheel again and looked and looked and looked, but can?t seem to find why there is so much play from the armature plate control arm through the plate and back to the twist grip? Usually these things are very sticky.
