1957 evinrude 18 fastwin point and plug gap?
driftwood1
Just got done putting coils points and condencer in.I know the point gap is 20 thou.Do I set the points at the open spot by lining up key with point rub.It says top close to it and I want to make sure.What is the spark plug gap for j6c spark plugs thanks almost have it put back together to try Driftwood!
R.Johnson
Re: 1957 evinrude 18 fastwin point and plug gap?
You've got it. set the plug gap at .030
sundede
You are ahead of me! 1957 johnson 18 hp! My lower unit had a broken impeller hsng. stud. I had fun getting the flywheel off, I could read the .20 setting for the points and the TOP A. on the cam. The (A) is an arrow, so I believe that is set point. My condensor & points looked good so I cleaned and set them.I have till Fri. to get paid so I can buy coils. Stud should be out by then. I had to free the over rev limit arm It blocked throttle. i also readjusted the throttle ring? for more open throttle while I was in there to make clean the wire end for the new coils.I took apart the tiller and was happy to fix it with a washer and grease. Bet you know just what I am saying! Plug was j6cgot equivalent Bosch uncle says .030 see ya. Kevin
tashasdaddy
sundede, it will work with bosch, but rudes prefer champion. i've got a '55 15hp, i run every weedkend, use Joe Reeve carb settings in the engine faq forum to set up the carbs.
