Ok, got my tank and connector, problem solved. Here we go with a new one. I hooked up the tank to the motor, finally get to see how my new motor runs. I pulled my butt off. Nothing. left it set for about 10 minutes. pulled it again and it let out a really loud sharp crack, Im going to assume this was a backfire. New gas, new plugs, took off the glass sediment bowl and filter, cleaned then all up. Getting spark. When I got this motor the guy had taken out the plugs, is it possible that the plug wires are reversed, whee to look from here. Thanks guys.
ALso, the lower lean/rich dial turns around in cirlces, it just doesnt turn from 1-6.
