1957 5.5 Johnson. Propeller doesn't spin.
sloopy
Re: 1957 5.5 Johnson. Propeller doesn't spin.
sloopy
Did you remember the thrust bearing?<br />
IA rookie
Sloopy, the first diagram is closest to my setup, but there are some differences. According to the manual I have (Clymer) everything looks to be accounted for and in proper location to work.
sloopy
if you wait to 1:30 I can go down to my boat and rip apart, mylowr unit, find out....<br /><br />SIT TIGHT!
44sparky
That model uses a spring loaded safety slip-clutch that sits just above the pinion gear. it can be checked with a torque wrench. it should slip at 155-225 inch pounds. of course this means taking it apart again.
slow_boat
Sloopy,<br /><br />Where can I find exploded diagrams like the ones you posted in this thread? Those are much clearer than the ones in my manuals.<br /><br />Thanks
sloopy
Well these ones I stole off of a site, but I have actory assybling manuals for some outboards :) I also have the actual manuals the motor companys give the mechanics, it had why more info and bettwe pictures then the manuals IBOATS sells, I got these from (subrise) the marina that burned down (it did not not spread to that area of the building)ask your outboard echanic (become friends) to let you photo copy some pictures :) <br />the masterteck like on that site those pictures came from,can copy them for you :)
IA rookie
44sparky, would that be under the impeller plate?
IA rookie
Well, at long last I may have figured out the problem. 44sparky was right on the money with the slip clutch. My manual doesn't show these parts, but I think I may be missing something. The lower half of the clutch is pinned to the top end of the short pinion shaft. Between the clutch and a shoulder on the shaft is a washer. I'm assuming this is a thrust washer. Should there be a thrust washer that fits between the pinion gear and the bottom end of the shoulder on the pinion shaft?
IA rookie
I would like to thank everybody for their patience and persistence. Your efforts paid off. The spring for the slip-clutch was broken, fortunately I have a second motor for parts and it did have a good spring-clutch in it. When I put the motor in the test tank it worked great. 44sparky, if you were close to Iowa I'd buy you a cold one.<br />Now I'm really anxious to get my boat in the water, but I probably won't get a chance until this weekend.<br />Again, thanks everybody and Happy Motoring.
sloopy
hey how many parts does this parts motor have?? I can buy i from you :)
IA rookie
Thanks for the offer Sloopy, but I think I better hang on to it. I never know when I might hit a run of bad luck(lol).
slow_boat
Sloopy,<br /><br />Which web site has the Johnson/Evinrude illustrations? I can't seem to find one that does.
slow_boat
Thanks Sloopy...but I do not find any illustrations on this site.what am I doing wrong?
sloopy
there in the part were it tells you how to rebuild a 3hp evnruder!
