1957 35hp golden javelin
Chuck stubbings
Help! I have a great 1957 Golden javelin I need to run it in salt water but I can’t figure out how to flush it afterwards ? Any advice ? And thanks I am new to this boat restoration project!
jimmbo
This out of a 1957 Evinrude 35 Hp Owners Manual
Click image for larger version  Name:	img042.jpg Views:	1 Size:	171.8 KB ID:	10864716
However you might still want to flush it
When you pull it out of the water, run it a barrel of fresh water for a while, keep a hose adding more water to the barrel so it over flows diluting the salt content..
There used to be a Flush adapter that clamped over the Water Inlet on the Exhaust Snout, it was made/marketed by a Company called Tempo. I have only seen one the last 30 yrs. You might find one on ebay.
Now, I know someone will say they use one of the Ear Muff Flush devices over a Water Inlet above the Anti-Ventilation Plate on the Port side of the Motor, I will not recommend it has caused problems.
Honorary Supreme Mariner
Amazing what they printed / wrote in the manual.-------Did the technical writers go to the same school that our present day political leaders graduated from ?----I suggest a flushing routine on that motor.-----Also recommend doing certain routines regularly.-------Like removing the lower unit / water pump screws.------Keeps them from jamming up and you can dip screws in sealer.
Chris1956
Actually motors of that era were very salt water resistant, like the manual says. Those motors were good aluminum alloys, SS fasteners and the rest was brass.
I had a '58 Fat Fifty and lost it off the boat in salt water while it was running at 1/2 throttle. It took me 60 hours to find it in the creek.
I figured that a 40 year old motor(at the time) would be finished, but after cleaning the carb, starter and distributor, I was able to pull start her. Hitting the cold salt water while running didn't cause any damage. Try that with today's motors....
I therefore think flushing a 60+ year old motor is unnecessary.
I think flushing is a good idea.----Sealing threads is a good idea.
