1957 18hp Evinrude fastwin.
kallaste
I have a 1957 Evinrude fastwin.I have rebuilt the carb,new plugs&wires,new coils,points,condenser. The motor seems to run best at high speed when the fast jet is almost closed(just cracked ) or leaned out. As I slow down I must richen the fast idle to transition back to an Idle. All this takes place with the slow jet opened at 1 turn.<br /> Does this make sense? Will it burn the motor up to run it so lean. What would the problem be?<br />Also this motor is fairly cold blooded and sensitive to starting procedure. example to start motor. 1. pump air into tank,no choke,turn throttle to start. 2.pull cord 2-3 times. 3. pull choke then pull cord to start & die. 4.push choke in, pull cord, motor starts and runs. Is this typical of this motor. Any suggestions? Thanks..
Mod2
Re: 1957 18hp Evinrude fastwin.
Moving to Johnson/Evinrude Repair Forum.
rolmops
Run it a bit richer both on the idle and highspeed.The best place is about a quarter turn counter clock wise beyond where you are now.
OBJ
What rolmops said and a bit more.....set the high speed jet first. Then set the low speed. Make sure the throttle plate is closed when setting the low speed.<br /><br />EDIT: Just one more thing.. :) Look at the cam follower lever and make sure that when the lever is at the hash mark on the cam, the throttle plates are just opening. This will set up the timing/throttle plate movment.
