1957 10hp johson HELPPP
hockeyfann
When i shift its a hit or miss. sometimes it snaps right in to gear most of the time i have to mess with the lever until in engages whats wrong do i need a new clutch do or gears i have no clue. The rods are connected!
Monte1961
Re: 1957 10hp johson HELPPP
try moving shifter with engine not running. Is it easy or is it hard? Be looking into the possibility of tearing down lower unit. Note: not as bad as it sounds. Not much to them. Post back yer results
Monte1961
give us the model # and with an exploded view, you will be more inclined to understand whats going on here. Post back your model #!
Monte1961
heres a exploded view. Monte
hockeyfann
model qd-18. any ideas as to whats wrong with it?
kfa4303
Banned
For starters make sure your throttle is twisted all the way down while testing the shifting so that the timing armature place won't get in the way. Then check the shift rod connector (part 41 above) to see if the upper and lower shift rods are connected. If they seem ok, try gently turning the prop by hand and see if you can shift the motor into/out of gear. If not, you may need to drop the lower unit. To do so remove the lower shift rod coupler bolt completely and the 4-5 bolts that hold the LU to the exhaust housing. The LU should then drop out (it may be a little stubborn, but be patient). With the LU removed try shifting into gear using the normal shifter. If it shifts into gear(s) easily, then you know the issue is in the gear case. Try these steps and let us know what you find. Hang in there. That's a great little motor you got.
hockeyfann
ok removed the lower unt and pulled and pushed on the lower shift rod. it moved up and down easaly but it was all smooth. i did not feel any click when i moved it.
Monte1961
you should have felt a detent between gears. If you didnt, you have to go into it further! I am thinking the detent spring is broke or has came loose.
freddyray21
that model does not have a detent spring. most likely the shift lever needs adjusting. common issue on them.
kfa4303
Banned
I would open up the gear case too. It's really not that bad. Be sure to check the tabs on the clutch dog. Unless someone has replaced it recently, which I doubt, it's probably worn. It doesn't take much for them to go bad. Make sure the shift lever pin (phillis head screw) is properly seated too. The gears themselves are super simple, just remember you'll be looking at everything upside down. There are lots of threads that can walk you through the job. You may want to consider changing the seals while you're in there. It's not too much work, only costs about $25 and is well worth the effort. Take pics for later reference if you're worried, but it's not that bad. Keep us posted.
nwcove
" If they seem ok, try gently turning the prop by hand and see if you can shift the motor into/out of " "quote"
be VERY CAREFULL when turning the prop on any motor, for any reason. make sure the plug wires are off, or even better, remove the plugs. rotating the prop, under the right circumstances ,could (and will ..i still have ten fingers.....start your engine)
hockeyfann
Sorry ive ben on radio silence. But i just found some time to take apart the gear case all of the screws are crodded and I cant get them to budge tried Liquid Wrench but that dident work. Any suggestions?
hockeyfann
Where can i get the right float. I bought one off of Marine Engine.com to replace the old one but ever sencie I changed the old one out I havent been able to get it to run smooth.
nwcove
is the float set level? did you put the tiny wire clip on that connects the new float to the float needle? (only ask because i just did a 1962 rude, that had no clip, and no spot on the old needle for one to attach!)
....what nhl team do you cheer? lol
kfa4303
Banned
Hi hockeyfann. You can get a carb float right here at iboats. Here: http://www.iboats.com/Johnson-Carbu...9654512--**********.845325980--view_id.271386
As for the screws. Try a bit of PB Blaster, if that doesn't work, then you may need to try a bit of heat to loosen the screws. Take your time so you don't snap off the heads of the screws. Patience is a virtue and will be richly rewarded. Good luck!
Chinewalker
Impact driver. I've used them many times on those units. However, they should not be corroded - they should be stainless. If the screws are not stainless, then someone has mucked around in there before...
