1956 or newerish johnson 15 hp cooling problem?
Renegade56
So im a new poster and i joined just cause i jave some questions since its my now 2nd old johnson and the first one did the same thing. The first motor i had was a 1956 johnson 7.5hp. Ran like a top the first time i used it. Also desided to self desrtuct itself the first time.i used it and is now locked up and im wondering if its the same problem. So when i ran the 7.5 in a small ish barrel no water came out the exhaust to create a "mist" when we brought it on the lake everytime i looked a nice steady stream was flowing out. And then i went to go move spots and it just slipped out of gear. I thought it was a shear pin but the lower end had crystal clear water. And after a day of it being home it locked up. Well i picked up my 15 hp tonight and it runs but still no "mist" in the same barrel. I put oil in the lower unit (80 90) and i also heard that there has to be thrust from the prop to get water to the pump. Im just afraid of burning another engine and i cant replace the impeller on my own. Also the nearest place that would be able to near me is 4 hours away. I guess my question is how would i know for sure that waters flowing through without me burning another engine or taking it all apart? Thanks!
flyingscott
Why can't you replace the impeller on your own. That one will be much easier than your 7.5 because the powerhead does not need to be pulled to do it. The prop does not need to be turning to pump water. Is the water in the bucket above the waterpump housing?
Renegade56
Im not good with boat motors or how they work or anything like that. And im not sure it was probably like 4 or 5 inches above the top fin. The water was below that bottom "knucle" that holds the front of the bottom end if you know what im talking about.
Renegade56
I think for the 7.5 it was the gear case that locked everything up but i cant be for certain. I mean if there was a steady stream oqf water i dont see how it could have overheated under 1 min with out being ran for a good 20. As far as the 15 hp all i really know is that its bigger and it was alot easier to get started the the 7.5 since i bought them. I bought the 15 from my friend who said he ran it probably 2 years ago. And the 7.5 i bought from a neighbor who said he ised it last year but with all of the problems i had with that one im certain it was longer than that
JDusza
I know, silly question.....what are you running for fuel mix? On an older one that hasn't run in while, I'd mix at something like 35:1; little more lube and a little cooler run
J
kmarine
If your impeller is more than two years old replace it or risk overheating and engine failure. If you cant afford to take it to a marine repair shop. $75 to $100 around here, find a friend who is a good mechanic and see if they can help you. The other alternative is to buy a newer motor that has been serviced.
Renegade56
I was running, 40:1 and 87 pump gas, and with the 15 im running 50:1 and 91 pump gas cause i heard it was a better mix for boat motors and easier starts things like that
Renegade56
How would you go about replacing the impeller on the 15 hp? I know that on the 7.5 you have to take the power head off and thats what im trying to avoid doing myself
lindy46
What year is the 15hp? If it is a 1956 model, it must be run 24:1. If it is the 1974+ model, it can be run 50:1.
Renegade56
Its around that year as it looks like my 7.5 and was red and white. Would 50:1 hurt it?
flyingscott
24:1 is the mix for that motor they have different bearings. To remove the waterpump look on the side of the exhaust leg for an access plate. Take the 2 screws out and the shift linkage connector is in there. Disconnect it and drop the lower unit.
jbuote
Actually, I think that's backwards...
​50:1 has LESS oil, therefore less lube than 24:1...
​By running 50:1 in an engine meant for 24:1, you're not lubing enough....
jbuote
No,
​50:1 is the fuel/oil ratio, so 50 parts fuel, to 1 part oil.. 50:1 is more gas per unit of oil than 24:1 (24 parts gas to 1 part oil)
Renegade56
So how many ounces of oil should i add to 4 gallons? I think i added like 20 or just under ill gladly add more oil! Lol dont want to burn out this motor with having less oil!
Renegade56
Btw, got the 7.5 unstuck.today. top end turns but not the lower when shifted into gear. Time for a new lower!
jbuote
Nice! Glad the 7.5 is freed up!
​As for the oil mix. Not sure where you are, but IF we're talking US Gallons which I'll use in my example below, you can convert it to oz.. 128oz is 1 US Gallon. (don't confuse with Imperial, or liters...)
​So basically, to calculate it, you divide 128 (for US) and divide by the ratio.. So 50:1 is 128 / 50 = 2.56 oz oil per gallon.
​24:1 is 128 / 24 = 5.33 oz oil / gallon.
​So, if you had say 5 gallons of gas (US) then 5 * 5.33 = 26.65 oz of oil. Add 26.65 oz of oil to 5 gallons of gas (US) and you will have 24:1 mix.
(EDIT: for your ​4 gallons, would be 4 * 5.33, so 21.32 oz of oil should be added to 4 gallons for 24:1)
​Hope that made sense... lol
