Not sure what bolts you mean, the ones that hold the starter bracket to the powerhead? I believe those are 1/4-20. There also is a larger one on the front. over the carburetor, 5/16-18 (?--not sure). Finally, the starter bracket is further supported by a bolt to the air silencer.
Or the thru-bolts holding the starting motor to the bracket? As best I remember, those are also 1/4-20.
You can use some blue Locktite screw lock on any of them.
Nuts?? Enlighten me on that. Does it have nuts & studs instead of bolts?
