1956 Johnson 15hp question
zino
I came across a 15hp Johnson FD-10, it is in nice original cond. I can probably get it for $100. The owner stated that he was using chain saw oil in it rather than outboard oil and the motor was giving him starting trouble. My question is might this engine be toast. What internal damage may have been done, anyway to check outside of a teardown.
oldcatamount
Re: 1956 Johnson 15hp question
Just do a compression test on it. If both cylinders read close to same and are at least 75lbs or over, it's fine! Great motor for 100 bucks!
