1956 Fastwin 15hp oil dripping down the leg
BonairII
This is anything to be worried about?
Daviet
Re: 1956 Fastwin 15hp oil dripping down the leg
Is the bolt loose/stripped? Damaged base gasket, maybe?
BonairII
Just checked the bolt(should of done that in the first place). It wasn't loose per se...but I was able to turn it 1/16th or so and snug it up. I'm guessing that the leaking will stop now.
boobie
I vote for the bad base gasket.
BonairII
Out of curiosity...is the base gasket expensive and/or a pain in the arse to change? Aside from small oil loss(assuming the gasket is bad, does a bad base gasket affect performance?
