Need some advice on this motor. Here's what I've done so far: New impeller, new Coils, condensers, points, spark plugs and wires. Gas tank cleaned and Redkote polymered. O-rings replaced on gas connector. New gas lines. Carb cleaned and rebuilt. It now starts first pull. Runs like an S.O.B. Here's the problem: It is not pumping water and when in gear, the prop is not turning. When on the stand and in neutral the prop spins free. When in gear, it does not spin. Is this correct? When in the tank, no water is coming out of the exhaust and when in gear, I'm sure the prop is not turning.
NOTE: This is my first rebuild of any kind of motor, so please be gentle. Thanks.
